file size is huge
in Other
how to delete solid history....right now I have simple edited cube on my screen, but the file size is 4,7 MB...if I draw the new one it is only 15KB
what about silmilar procedure?
blog.microsolresources.com/2013/08/23/autocad-large-file-size-problem/0 -
strange file attached (4,7MB)0
Hello Leino,
Please create a supportrequest for this. We'll investigate it.0 -
Wow, impressive - hundreds of thousands of junk lines in the ACIS description, without audit or solidedit/check even complaining... how did you do this?0
answer form bricscad support:
"The model you started from was created with BricsCAD V13 using 3d constraints/direct modelling tools. Indeed sometimes such models size can undesirably grow when edited in BricsCAD V13 or V14. If you recreate the model in BricsCAD V14 the size problem will not appear.
We expect to release a fix for working with such V13 models. Thank you letting us know."
I hope to see this fix soon as possible...I do not want to start over agin thouse hundreds of solids models...0 -
Thanks for sharing.
I never used constraints, so this will probably not hit me, but I agree a fix is critical in order to not discredit the whole thing.
As far as I know, there is no API for constraints, and the fact that it might introduce a big heap of totally inaccessible data into models (I thought it would rely only on extended entity data) is not going to boost acceptance of this technology...
