Lisp & DMPUSHPULL
 Lisp how to use DMPUSHPULL command?
  • There is a strange problem if you call _DMPUSHPULL from a Lips function. Somehow a selection window gets started. So the code seems to generate a rogue mouse click.
    [code](defun c:test ( / dist ename oldOsmode)
      (if
        (and
          (setq ename (car (entsel))) ; Check for valid entity is required.
          (setq dist (getreal "\nPush/Pull distance (negative value for push): "))
        (progn
          (setq oldOsmode (getvar 'osmode))
          (setvar 'osmode 0)
          (command "_.dmpushpull" ename "" dist)
          (setvar 'osmode oldOsmode)
      (princ)
    )[/code]
  •  Hi Ray,
    It don't work.
  • If the contour is attached to a 3D solid the code works. But, as mentioned, there is the issue of the rogue mouse click. I don't know how to solve that. Maybe you should file an SR regarding that problem.
