Assembly Modeling grid
In assembly modeling, is there a way to hide or turn off the grid that is on the X-Y plane? Or at least to re-size it?
If it matters, I am using 14.1 Platinum.
James,
In all versions you can toggle the grid on/off by:- Pressing F7
- Pressing Ctrl + G
- Picking "Grid" on the bottom status bar.
You can adjust your Grid size by:- using the _GRID command
- Right clicking on "Grid" on the bottom status bar, and selecting "settings" from the pop-up menu.
You can work with _SNAP in a similar way
if you download BricsCAD for AutoCAD users you'll find a handy summary of these type of quick keys in the appendices.
Regards,Jason Bourhill
