Snaps Being Picked Up Off Screen
Hello:
I've noticed that if I am attempting to modify an object (using move or copy commands for instance), or draw a new object, at times the application will grab an object snap that is outside of the current view - it seems as though the midpoint snap is the worst offender.  I usually run the program with osmode set to 47 and notice that the off screen snap issue described above is most prevalent when I attempt to pick a point without a snap - the application searches for a snap point to use and grabs one way off in space instead of one near any objects.  Is there a setting that allows you to set an 'object snap search radius' to prevent the application form grabbing a snap that is off screen?
