Printing pdf in V14 faulty.
 I have setup our A3 borders with fiducial marks at the bottom left and top right.
In BC v13 these borders printed correctly to pdf. In otherwords they printed all exterior border lines and were centred on the page.
In BC 14 I have the problem that the border does not centre on the page and always drops off the top border line of the sheet.
I have tried three different pdf programs to verify this issue. I routinely use Adobe pdf to write the files and I have tried PDF creator and PDF Architect.
All three produce the same result.
Once selecting the fiducial marks, previewing and applying the main CAD view would respond with the background aligned to the picked points. In V14 this does not happen, the background slides down towards the bottom left.
Any help would be appreciated.
  • Max,
    Is there any chance you can attach your dwg file and the two pdf's from V13 and V14 so I can see what you are trying to achieve.
    I have had a few spurious things happen with PDF's so I might be able to shed some light on your problem.
    Rgds,
    David
