How do i change mesuring units?
I have some drawing where the units are millimetre, and when I make dimensions I get it in milllimeters.
I would like to have it in meters as it is a large scale drawing.
I have tried some settings UNITS, DDIM but it keeps showing in millimetres.
I am using Bricscad V13.2.10
You could set Primary Units / Dim Scale Linear to 0.001 (either in the Dimension Style specification in Drawing Explorer, or in the Properties window as an override for any individual dimension entity). You might also want to adjust Dim Precision, unless you want the dimensions rounded to the nearest whole meter.0
