AEC Objects
Hi there,
Since upgrading to version 14 I keep getting this message when I set up a new drawing using my Lisp routines.
"Saving the drawing will update any AEC objects to the current version, which will be incompatible with earlier versions."
Why? Any dwg files that I use have been converted to Release 2013 DWG format.
Is there any way to turn the message off?
Thanks in advance for your help.
Phillip
