3D dimensional constraints: mathematical expressions and variables in parameters
I am a draftsman.
I worked in steel industry in the past and I am currently working in processing plants.
I have experience in other 3D-variational-parametric systems such as: 'Pro Engineer' and 'Mechanical Desktop'.
I find it very good BCAD V13 (in general terms). The cost-benefit ratio is excellent. I'm using BCAD from the V7 version.
I'm trying to implement my designs in 'BriscCAD V13' for Windows.
However I encounter the following problem:
In 3d dimensional constraints I can not apply mathematical expressions or names of other parameters. While it can be made with dimensional constraints 2d.
I have not found a solution to this problem in the help files, or internet forums.
Is there a solution to this problem in the V13 version?
Of course, thanks for your attention.
            You need V14 for this.
From the V14 Release Notes:
Version 14.1.01 29/10/2013
New:
3D CONSTRAINTS: expressions and parameters can be used to specify the value of a dimensional constraint. Parameters of dimensional constraints can be used in expressions as well.
...0
