V13 "look from views" not working
in Other
This is weird. Using the view toolbar/look from & selecting any of the "regular view directions" - top, front, right etc does nothing, just stays in top mode. This has been going on since upgrading to V13 but finally have the time to look into it. By contrast the isometric views work fine. Anyone else encounter this?
I noticed that a while ago, they work again in the last few versions of V14.
At least, I doubt it was caused by a setting in any particular file.
I rarely use them so didn't bother to look into it.
There has been an issue with orthographic views all restoring the Top view in V13. It was fixed in the latest V13.10 update, which still can be downloaded from our download page (choose Old Releases). The problem was related to the value of the UCSVP system variable. If the variable was OFF, the problem occurs, if ON orthographic views (front, left, right, back) are restored correctly.0
As a matter of fact Im running 13.2.10 and it not working. This is the only "old realese" I can see..
I've pointed this out earlier.
Patrik
Sorry sometimes you hve to read the whole post. UCSVP off works.
Patrik
I have the latest V13 version, but UCSVP set to off does cure the problem. Thanks!0
I have the latest V13 version, but UCSVP set to off does cure the problem. Thanks!It appears the fix was not applied until V14. My mistake, sorry.0
