Database Lisp programming on Linux
I'm used to windows programming and want to migrate to linux programming.
Using lisp. is there a way to access a database backend? (namely mysql).
If I write a program in another language, can I start the executable, set a few parameters (ie. connection settings), execute a query and read results.
I did ask the question a few years ago. But I thought I would ask again to see if anyone had actually done it.
There is a great Lisp interface for MySQL, written by Daniel Marcotte ...
it is a TX (C++) module which can be loaded into BricsCAD, both Windows and Linux versions are available.
You should find it here in the forum somewhere.
Many greetings !0 -
Hi Torsten.
I can't find it. I found something for bricscad v12 and sqlite. and it appears to be C#. Is this what you are referring to?0 -
Yes, it is the interface for sqlite
http://www.cadext.com/downloads/SQLiteLsp.zip
I assumed, Daniel had used C++, and I had in mind that this plugin would also work under Linux (based on BRX + TX interfaces).
You might ask Dan in that forum thread about this ?
Many greetings !0
