Copy and paste from other open drawings
Ok, this may be a real bone headed question, but I really don't know the answer. I frequently open more than one drawing and copy and paste objects from one to the other. Sometimes the paste operation drops the object right where I direct it to with my cursors. Other times, it drops the object a long distance from my intended target. I have to ZOOM EXTENTS, spot the object (typically very small), and then move it where I want.
Why is this, and what can I do about it?
Check the BASE variable in your drawings. If they vary (not 0,0,0) this could be the cause. Also look into the PASTEORIG command.0
...or just use COPYBASE instead of COPYCLIP.0
Jim,
I would check your INSUNITS in source and target drawings. If you are regularly dealing with old AutoCAD drawings, or drawings exported from another CAD application, then you may also want to consider INSUNITSDEFSOURCE INSUNITSDEFTARGET.
BricsCAD respects these variables when copying and pasting between drawings (AutoCAD ignores them).
Refer to these previous posts
https://forum.bricsys.com/discussion/23064
http://forum.bricsys.com/discussion/21763
Regards,Jason Bourhill
Thanks guys. Really good advice as usual.
The BASE variables in source and target drawings were not even close. They differed by orders of magnitude! INSUNITS of source and target were 0 and 1. Not sure what the BASE and INSUNIT variables define, or why they were different. I'll have to delve into that further when I get free of the rush job I'm doing for the boss.
PASTORIG dropped the object much closer to where I want to place it (apparently at the WCS origin). COPYBASE is the cat's meow! When I issue that command, the subsequent PASTE drops the object right where I position my cursor. That is my solution for now.
I recall that when I first started working with Autocad R14, (15 years ago?), the program always asked me to assign a drawing size (corners or limits of model space). I didn't know what I was doing. I just assigned arbitrary values. I setup some templates with this process, and ever since have started new drawings from those templates. I'm wondering if that is the cause of my problem.0
