Multi-Line - Extend/Trim, Entity dimension
Im trying to see if it's possible to extend or trim a multiline, additionally it would be very helpful if you could do an entity dimension of a multi-line. does anyone know if there is a way to do this?
I tried to find a solution for this. Pretty sure there is a way with the trim function but I couldn't find it.
In the end I just created a new multiline.
A solution might be to explode the mlines into lines, which can then be trimmed or extended.
