Annotative blocks
Can somebody please help me? I am trying to make an annotative block have a particular annotative scale while having a particular scale in a view port. I have attached the block if you would care to play with it. It has several attributes (only one is visible). When I originally created the attributes they were annotative. Buit if I open the block after it has been written to the hard drive I notice the attributes are not annotative. Therefore I had to set the ANNOTATIVEDWG variable in the file to ON. I must be doing something wrong. I have not seen very much in the forum about annotative blocks.
Just to let anyone who is interested in this topic, according to my tech support person, their is a bug in BricsCAD. The problem has been turned over to their development people.0
I find that an annotative block does not scale at all. Is that your bug?0
Yes, I have also come across this. It seems to be a bug. It has been reported to the support team.0
Thank you for the confirmation Rajesh.0
Thank everybody for their help. I just hope when the programmers solve this bug they make sure they check everything related to annotation.0
