Bricscad V14
Hallo,
in Bricscad V14 the follow code not working:
(initdia 1) (command "_MTEXT")  (while (/=(getvar "CMDACTIVE")0) (command pause))
Mtext has with V14 no dialogbox.
Is there an alternativ command for  "initdia"?
Christian Köhler
  • Please send us a support request ... should work in BricsCAD, using MText dialog, as you mentioned.
    We should fix this.
    Many greetings !
