Lot Closure, Map Check, Areas
Hi there,
Re: Lot Closure, Map Check, Area software
I am looking for a routine or a stand alone program that would allow my client to check the textural content of land boundaries on a drawing; to confirm they close mathematically and also to determine the parcel area.
I know there are some programs where a map checking is a feature in a much larger program but I simply looking for only the map checking feature.
Thank you in advance for any help you can offer.
Phillip
Hi Phillip,
If you don't mind a third party software that is light-weight, you may want to consider trying GeoTools:
http://www.coordsys.com/geotools
I have attached a complete commands list for your reading. If you have specific questions, please email me.
rakesh.rao(at)4d-technologies.com
- Rakesh RaoHi there,Re: Lot Closure, Map Check, Area softwareI am looking for a routine or a stand alone program that would allow my client to check the textural content of land boundaries on a drawing; to confirm they close mathematically and also to determine the parcel area.I know there are some programs where a map checking is a feature in a much larger program but I simply looking for only the map checking feature.Thank you in advance for any help you can offer.--Phillip0
