Function "Mirrtext"
 I would like to know the best way to me
·         Function "Mirrtext" does not work on texts by "Leaders" and "Multleaders";
Thanks,
Eric Rodrigues
  • It works here (v14.2.10)
  • ... There is a problem with multileaders: The mirrored version has the text upside down.
  • Olá,
     "O mirrtext está funcionando na v14.2.10. "
    - Esse comando não funciona com a entidade "Multleader". Em texto "soltos'" funciona perfeitamente, mas com essa entidade não.
    "It works here (v14.2.10) "
    -  This command does not work with the entity "Multleader". In text "loose '" works perfectly, but with that entity no.
     Eric Rodrigues.
