Acrobat x paper sizes
I just installed acrobat x on my machine.   I don't seem to have any of the standard architect paper sizes.   ( A B C D E,  Arch A Arch B  .....)
any ideas ?
JP
  • Assume you have the "Standard" version? I believe Arch paper sizes are only supported by the "Pro" version.
    Suggest alternative viewer (many are free).
  • All Paper is supported by x standard per a "dear customer reply" on the adobe forums.
  • Assuming you are using BricsCAD, why not use EXPORT to pdf?
  •  I tried the export to pdf a few times and was not able to get the scale exact.   The plot interface is also much better for control.
    I installed the postscript drivers that allowed me to define custom paper sizes,  so problem solved.
    JP
