Small Refedit Toolbar-accidentally Closed it
Greetings,
I am using BricsCad V13 (x64). I accidentally shut down the little dialog box that pops up when you start Refedit. I can manage without it but I would like to get it back.
Any hints?
Thanks,
Doug
Did you invoke REFCLOSE command after editing?0
If I recall correctly, it should come back the next time you do a refedit. However, it may not be in the same spot it was before. It is not a large toolbar, so it may be hiding somewhere you didn't notice before.-Joe0
Robt Deans,
I did use RefClose. I have been using it and then, I X'd the little box out without thinking and can't figure out how to get it back.
Joe,
If it has come back, it is hiding under something. I have used Refedit multiple times since I inadvertently closed the little bugger and I don't see the box reappearing anywhere.
Thanks,
Doug
I decided to be brave and actually press the little red-x myself. I know I have done this in the past, and do recall having a problem getting it back. But, I didn't recall the exact process.And, to my surprise, it came back all by itself, without any effort on my part. I even X'ed it, and then quit Bricscad. It still came back the next time I started Bricscad and then did a Refedit. I should mention that I am on v14, in case you are on a different version.-Joe0
Joe,
I tried shutting down Bricscad and starting it up again, then invoking REFEDIT. It didn't reappear for me. I am using V13.
Thanks,
Doug
Did you try right click on main toolbar @ top of screen BRICSCAD / REFEDIT?0
To open a toolbar, right click on any toolbar, then choose BricsCAD in the context menu and select a toolbar in the list. Toolbars that are already open are checked. Clicking an open toolbar, closes the toolbar.0
Robt and Louis,
Now I found it. It had been floating before and when I did as you guys said it showed up alongside the other docked toolbars.
Thanks for helping
