Prefix Sheet Number to PDF Name?
Hello,
I am wondering if I am missing this feature or if someone knows how to add this functionality to sheet sets. I would like to Publish sheets within the drawing explorers sheets tab, when I publish to PDF with the publish option, the PDF file's name is just the sheet title. I need to have the sheet numbers prefixed to the sheet title for sheets to be placed in order (this seems to be the default option in AutoCAD to prefix the number to the PDF name). So for example the PDF name needs to be "1.0.0 - GENERAL NOTES".
Thanks,
Steven
  • Sorry I don't know, but that was the main decider when I chose PDF-xchange to do PDF's - it defaults to the file name + Layout name as a first suggestion for the PDF name.
