: dmFix3d
How does one select an entire 3d solid and not just a face or edge with the dimFix3d?
Using the Tab key will scroll through the faces located under the cursor, after scrolling through the faces, the entire solid will be highlighted.
Using Shift-Tab will scroll in the opposite direction, so pressing it once will select the entire solid.0 -
Thanks that worked0
