How to plot dwg to pdf file in VBA?
Hi
1. How to plot dwg to pdf file in VBA?
2. Any plot-to-pdf software is best?
Thanks
Her is sample code, print with PDFCreator from AutoCAD.Anybody can modify the code to run in BricsCAD!Thanks
Private withevents mypdf as PDFCreator.clsPDFCreator
private readystate as boolean = true
private sub pdf_create()
mypdf = New PDFCreator.clsPDFCreator
If mypdf.cStart("/NoProcessingAtStartup") = False Then
mypdf.cClose()
mypdf = Nothing
Shell("taskkill /f /im PDFCreator.exe", AppWinStyle.Hide, True)
End If
Dim dp As String = mypdf.cDefaultPrinter
With mypdf
.cDefaultPrinter = "PDFCreator"
.cClearCache()
.cOption("UseAutosave") = 1
.cOption("UseAutosaveDirectory") = 1
.cOption("AutosaveDirectory") = "C:\Your\Directory\Path" 'Make sure you leave off the trailing \
.cOption("AutosaveFormat") = 0
.cOption("AutosaveFilename") = "your_file_name" 'Make sure you leave off the .pdf
.cOption("PDFUseSecurity") = 1
.cOption("PDFOwnerPass") = 1
.cOption("PDFOwnerPasswordString") = "your_pass"
.cOption("PDFDisallowCopy") = 1
.cOption("PDFDisallowModifyContents") = 1
.cOption("PDFDisallowModifyAnnotations") = 1
.cOption("PDFHighEncryption") = 1
.cPrintFile("C:\Path\to\CAD\File.dwg")
.cPrinterStop = False
readystate = False
Do While Not readystate
Application.DoEvents()
Loop
.cPrinterStop = True
.cDefaultPrinter = dp
.cCloseRunningSession()
.cClose()
End With
mypdf = Nothing
end sub
Private Sub pdf_ready() Handles mypdf.eReady
readystate = True
End Sub0
