Auto publish
Is there a similar command in Bricscad to Autocads auto publish command?  If not is there an easy way to generate pdf files from a series of separate Bricscad drawings?
  •  The 'Publish to PDF option' of the Publish command allows to either create a single multi-sheet PDF or a series of PDF's of the various layouts in a sheet list (*.dsd) or Sheet Set.
  •  Louis, I am having issues with this publish feature working correctly. The other post in this forum explains the problem I am having.
    Grant, if you like the keyboard then the publish command as Louis speaks of works, but if you like the gui or want another option then look for the little scroll icon at top. Also, I am curious do you require your PDFs to have a sheet number prefixed to sheet title in the PDF file name?
    You can also add something like:
    [code]PB, *PUBLISH[/code]
    into your default.pgp file within "C:\Users\%username%\AppData\Roaming\Bricsys\BricsCAD\V14x64\en_US\Support" for Windows 7. After saving the .pdp file REINIT to re initialize things such as the default.pgp file.
