unexpected end of file
I am coming across this error occasionally when opening an Autocad File "unexpected end of file Make sure the file is a valid dwg drawing then try using "recover" to load file"
I have tried using recover. The file then opens but has some elements of the drawing missing.
Any ideas on how to overcome this problem or to rescue the complete file? File loads OK into AutoCAD.
Thanks
Richard
  •  File a support request and attach a faulty file. It's pretty unlikely that any users will be able to help you.
    Regards
