Plate n Sheet for Brics?
in Other
I've used a demo for the Plate n Sheet unfolding program and it would be fantastic if Brics could integrate something similar into the base program.
It pretty much unfolds any 3D shape - cones, transitions and etc. Only caveat is this magnitude of programming would bump the price up at least a grand but still compared to Sworks and the like it's a bargain. Just a thought.
Plate 'n' Sheet will work with Brics ... its actually a stand alone and creates DXF so you can import the model and the flattened templatestheres a video there you can view to explainhope this helps0
I actually use http://www.hvacdevelopments.com/ software with Brics, also its stand alone, good and affordable price.
Regards.
