Suddenly sluggish performance and different highlighting
All of a sudden, at some point today my BricsCAD v14.2.13 started behaving sluggishly when I create crossing windows in preparation to stretch. Also, when I move my mouse over an object, it used to turn into dotted lines, but now instead it turns blue with a thickened line.
I didn't deliberately change any settings that should affect this, but perhaps I did something accidentally. I checked what the highlighting setting is at, and it was at 0 (stipple). I tried the other settings, and nothing changes how it highlights. I tried using a different color for highlighting, and that too is ignored. It is as though all the highlighting settings are ignored.
I tried rebooting, without any change. I did not do any windows updates, though there was a Java update today, but that was after the problem started showing up.
Any ideas?
-Joe
Even though I was in 2D wireframe before, (I checked it) I tried changing to 3D mode, and then back to 3D wireframe. That solved the problem.-Joe0
Oops, after I pressed enter, I caught an error. I should have said I switched to 3D and then back to 2D wireframe.-Joe0
