circle tangent tangent tangent
 hi all
just started using BricsCAD v14 was using Autcad 2010.
Autocad has a command Circle Tangent Tangent Tangent which was very handy but i can't seem to find it in BricsCAD ,
is in BricsCAD  or can i get a lisp routine that will do it
cheers
jim
  • Try using the 3-point circle and selecting the tangent esnap for each point.
    This lisp should also work:
    (command "circle" "3P" "_tan" pause "_tan" pause "_tan" pause)
  • @Jim,
    Have you tried the AI_CIRCTAN command, I think this should do what you need.
    David Waight
  •  Hi David
    that's perfect many thanks
    cheers
    jim
