Inserting Block
When inserting blocks, is there anyway to get the last block inserted as the default that comes up instead of it using alphabetical order?
You need to explain how you insert blocks. Using the _INSERT and _-INSERT commands the block that was last inserted is always the default.0
I just type "I" for insert, but using the pulldown menu the same thing happensI do run autosd also which is a program for steel detailing within BrisCAD, maybe that is what changes things. It's a pain in the arse when I'm on a drawing that I have to add a lot of blocks to.0
The INSNAME variable is used to store the name of the last inserted block. Perhaps 'autosd' overwrites the variable.
You can check this by comparing the INSNAME value before and after using 'autosd'.0
