Converting DWF to any other format
 Is there a workflow to convert DWF files into another format, preferably DWG or DXF.  I regularly receive automated DWF from a service authority and wanted a way to quickly convert this into something usable.  I don't believe this format is usable in bricscad.
Thanks
  • The best option is to request the author of the DWF for a DWG. There is a reason people use DWFs and PDFs instead of DWGs.
    Other than that, there are 3rd party softwares for such conversions. Suggest Google "dwf to dwg converter".
  • I think Autodesk's free program called TrueView can open DWF files and save them as DWG.
  • ...TrueView can open DWF files and save them as DWG.
    I believe Trueview can only convert AutoCAD versions. Suggest to the OP: Upload dwg(s), I can convert.
