Purging nested data
Hi there,
I wonder if it is possible (using the PURGE) command to purge nested data?
Thank you in advance for your help.
Phillip
Does your reference to nested data mean nested blocks. If so you need to perform the purge command up to 3-times consecutively to get rid of all nested entities.0
