{vb.net] eNoDatabase error
Hi All,
I'm currently developing an app that is intended work within both BricsCad an AutoCAD. I have a sub-routine to add entities to the drawing which also sets the entity's layer. This subroutine works within AutoCAD but fails in BricsCAD with the following message...
Message: eNoDatabase
StackTrace: at Teigha.DatabaseServices.Entity.set_Layer(String val)
Does anyone know a solution or work-around for this?
Cheers,
Pete
Hi All,
StackTrace: at Teigha.DatabaseServices.Entity.set_Layer(String val)Does anyone know a solution or work-around for this?
Cheers,
Pete
Hello Peter,
Try calling setDatabaseDefaults on the entity, before setting the layer property
cheers : )
Hello Peter,
cheers : )
Hi Daniel,
Thanks for the suggestion, unfortunately it still didn't work. This is my code snippit for adding a line...
Dim startpoint as New CADGe.Point3d(p.USManhole.Easting, p.UsManhole.Northing, 0)
Dim endpoint as New CADGe.Point3d(p.DSManhole.Easting, p.DSManhole.Northing, 0)
Using line as New CADDb.Line(startpoint, endpoint)
line.SetDatabaseDefaults()
line.Color = ConverttoRGB(p.colour)
line.layer = "MD_Pipes"
AppendEntity(line)
End UsingAs I said, this works in AutoCAD but not in BricsCAD. Any help would be very much appreciated.
Cheers,
Pete
interesting!
you might try setting the properties after append entity.
Dan
BTY, you might want to file a support request so the developers can take a look
Dan
