Drag a drawing (not a block) from the Drawing Explorer into an open drawing
I am probably expecting the drawing explorer to work in completely the wrong way, but I would like to be able to drag a drawing that is in my folders section of the Drawing Explorer into my open drawing.
I don't really want to make my drawing a block so I can do this, as these are predominantly parametric drawings, so I can't see why I would want to make it a block as there will only ever be one design in each drawing file.
I know that I could probably do this using tool palettes, but there are quite a lot of them and this could become quite unwieldy even with multiple tabs.
Am I doing this completely wrong or is this perhaps a function that could be incorporated into Bricscad in a later version?
I have attached a .jpg to illustrate what I am trying to explain.
Thanks for any help in advance.
David Waight
David Waight
Hi David,
Try right clicking on a drawing in the folder list. This provides 3 options:- Open Drawing
- Insert Drawing as Block
- Add to current Tool Palettes as a Block
Regards,Jason Bourhill
CAD Concepts0 -
Jason,
How thick am I!
I don't know why I didn't think to try right clicking!
This is close enough, so thank you very much for this; just a shame it can't be brought in exploded.
Thanks very much for the quick and simple reply.
David Waight0
