Printing HP Designjet T120
Have HP T120 and can't print big sizes sheets (A1, A2 or A3). Only can print A4 format.
I'm using Turbo print drivers. No problem with other software, like Evince PDF.
Thanks any help
  • Since you can print from other applications, it might be a bug. I would:
    1) Open a support request.
    2) While it's not fixed I'd print to CUPS-PDF in BricsCAD and then print the pdf file from Evince or other.
