Grid Color Options
Hello,
Is there any way to get more than the pre-picked colors for the snap grid lines and the drafting background color? I would like to have a larger selection so that the display is easier on my eyes, but it is dificult with only the choices available.
Thanks.
Thanks.
You can change the grid colours using the Settings command (Settings menu, Settings...) and searching for grid, you will see the options to change the grid colour under Drawing > Drafting > Coordinate Input > Snap/Grid. The variables that you need to adjust are GRIDAXISCOLOR, GRIDMAJORCOLOR, GRIDMINORCOLOR. The main Drawing area background colour can also be changed, again in the settings dialog, under Program Options > Display, Background colour, and paper space background colour are the ones that you need to change here. Their variables names are BKGCOLOR and BKGCOLORPS, there are also other options for gradients when in a 3D Home view.0
... To get more colors than in the initial dropdown lists choose the 'Select color...' option at the bottom.0
