Bricscad Linux v14
I have Bricscad Linux v11 right now.
Will v14 30 day trial install without disrupting v11?
Does the 30 day trial uninstall ok if I choose not to upgrade?
  • In theory, the answer to your questions is yes - the licensing information is separate, and the program installs into separate locations.
    However, I never used V14 in conjunction with V11, nor did I de-install it, so I cannot say for sure if there are problems or not.
    Anyway, the config file is shared between versions, so you might want to keep a copy of your .bricscad directory to be able to restore everything to its prior state if you decide against V14.
  • Yes, it's a good idea for me to back up v11.
    Thank-you for your answer.
    This question is resolved.
