Viewres and PDF Export
No answer on this?
I discovered this issue too, VieRes is supposed to be VIEW only, absolutely should not be controlling or have any affect on PDF renders full stop! But it does.
Also helps to have FaceTres at 10 otherwise 3D faces look like polygons.0 -
The value for viewres appears to be in the extended data as a 1070 value, the only issue I could see is that there are multiple 1070 values.
Thinking more about it for single mviews could be as simple as this. If you have multiple mviews need to go to each one and do a Mspace then set, more code needed.
(defun c:vres ( / lay lays)
(setq lays (layoutlist))
(foreach lay lays
(setvar 'ctab lay)
(command "mspace")
(command "viewres" "n" 1200) ; change number and maybe "N" to "Y" not sure
)(princ)
Very old thread. But, thanks for the example of lisp that pages through the layouts.
