Generated View Settings
Hello:
I have built a 3D model and beginning to generate drawings from the model, but I need to tweak the output from the generated view command - VIEWBASE.  I would like to disable the output of tangent edges, or have them placed on a separate layer and I also need to display hidden lines in a section view but I only get the object lines.  Is it possible to adjust the parametres of the program to obtain the desired results?
Thanks!
