uninstall bricscad from ubuntu 10.04
Hi, I installed Bricscad v14 on Ubuntu 10.04 only to find out it doesn't work, it doesn't even open when I click on it. According to Bricscad Ubuntu 10.04 is no longer supported.
However, I want to uninstall it and it doesn't even show in the software center to remove it.
Any ideas on how to achieve this?
I think nothing was installed in the first place. The installer dependencies cannot be satisfied on 10.04, the c runtime is too old.The installation location is /opt/bricsys/bricscad/v14. Probably it does not exist.Our policy is to build BricsCAD on the oldest Ubuntu that is still supported for the desktop, which is 12.04 LTS.0
Hi, thank you Tijs, sadly I read about your policy after trying to install ;P he he, I will check if the location exists.
I will probably upgrade to 12.04 now that there seems to be a stable linuxcnc controller for it too and try again.
Thanks for this great product.
Have a nice day.0 -
Hi, just wanted to let you know that I checked this and the folders does exist, however, if I click on the exe file it doesn't start.
For some reason, Bricscad now appears in the Ubuntu Software centre so I was able to uninstall it from there, looking forward to update to 12.04 to have Briscad working.
Have a nice day
Alfredo0
