Custom ribbon for V15
Is there any documentation on how to add a custom ribbon in V15
Wolter
I've got a existing *.cuix file that we use for autocad, can this file be recycled?0
I have a custom cui that I use with BricsCAD. I'm not able to add a custom ribbon to it either? I submitted a support request during the beta and have not gotten any answer ...0
i'm also interested to hear how to add a custom ribbon for my app.0
Tools -> Customize -> Workspaces - Ribbon - (right click mouse) Append Ribbon tab0
You can only append existing ribbons. I want to add custom ribbons0
Add or create ?0
Firstly CREATE and the ADD0
I have a custom cui that I use with BricsCAD. I'm not able to add a custom ribbon to it either? I submitted a support request during the beta and have not gotten any answer ...If you get a answer please share with us0
I got an answer.
When a partial CUI is loaded and the CUI does not contain a section yet, the Customize dialog doesn't detect this and it doesn't add ribbon branches.
This issue has been solved already by our developer team in the intern code.
I will notify you when the fix is available in a public release.0 -
The current download, v15.1.08 includes the customization of ribbons.0
Thank youDownloading now, will try to add my custom ribbons0
Managed to get the ribbons working.Just one thing that concerns me.If I load the cui file via c# it will load the CUI but will not display the ribbons. (I do this after a user instaale my add-on). If I however unload the file using the CUI (CUSTOMIZE) command, and the reload in the GUI everything is working.Has anyone experienced the same or is there maybe something wrong with my CUI file.0
Teach me How to customize ribbon in BCV15 through API0
