how to attach reference drawing from tool palette without dialog box
In AutoCAD I have a tool with this command:
^C^C-Xref Attach O:/CAD_Files/05_TOPO_NL-ALGEMEEN/Gemeenten/_Totaal/Gemeenten_NL.dwg;0,0;1;1;0;
When I use this in BricsCAD I get a dialog box and I have to locate the map manually.
How can I tell Bricscad to open the file, and not give me the attach dialog box?
Sander
  • Try
    [code]^c^c(setvar 'filedia 0);_-xref;_attach;D:/Test.dwg;0,0;1;1;0;(setvar 'filedia 1)[/code]
    Note: in your original macro you are using both spaces and semicolons as enter. I prefer to use semicolons only.
  • Yes - that works perfect.
    Thanks for the advice Roy.
  • Dear All.
    however, there is a strange thing ...
    using "_-XREF" should never open the filedialog. as the "-" hyphen in command name indicates.
    If "_-XREF" would indeed open the dialog, please send us a support request, likely with you menu
    (trying _-xref ...) on commandline works fine - no dilaog.
    Many greetings !
  •  I double checked, and without 'setvar 'filedia 0' the dialogue box opens.
    I have send in a support call.
