Bricscad 15.1.08 crashing on move command
Not sure what's going on but I am consistently crashing while using the move command today. I just updated to 15.1.08 last night and was using the release version of 15 yesterday so I'm not sure if this is a bug in this release but I didnt have the problem yesterday.
I have audited the drawing and it contains no errors but once I invoke the command and autosnap (perpendicular) to move the selected objects bricscad crashes every time.
Any ideas?
Any ideas?
Dear Mr. WoodPlease send a support request and attach the drawing. If possible add a scenario to reproduce the error.Kind regards0
I have not seen this exact problem so I can't speak directly. but have you tried a WBLOCK to a new file? We have had several outside files which were causing some of our lisp routines to misbehave, and the problems were fixed by a WBLOCK. The original files we had problems with were exported from something other than Autocad or Bricscad.0
Thanks Guy's
A support request with the .dwg has been submitted.0
