Hatch Pick points
Can someone tell me how i get pick points to a hatch?
I want pick points in the corners of my hatch so i can edit them easily. Now there is only a pick point in te center of the hatch.
Grt, Tim
  • In BricsCAD V14 and older, non-associative hatches have a center grip. In BricsCAD V15 additional corner and midpoint grips are available.
  •  In V14 you can use the HATCHGENERATEBOUNDARY to generate the boundary of a non-associative hatch, then use the Reassociate option of the HATCHSETASSOC command to associate the hatch with its boundary.
  •  Is there no other way? I just bought V14  pro and this is a big disappointment for me!
  • No there is no other solution.
    Download V15, run it as trial and check out the hatch there.
    V15 comes also with a Ribbon menu and BIM version.
    Keep in mind that the tirial is V15 Platinium.
    Like the test? Upgrade to v15.
    I believe you ordered BricsCAD earlier this month, so you already have a BricsCAD V15 enabled license key.  You should be able to simply download BricsCAD V15 and start using it.
    Best regards,
    mark
