Seleccion previa----Previous Selection
Buenas tardes, en la version anterior, la seleccion previa era "p", en la nueva version es "sp" (En español). Existe la forma de modificarlo con alias, como si se tratase de un comando?
Good afternoon, in the previous version, the previous selection was "p" in the new version is "sp" (In Spanish). There is a way to modify alias as if it were a command?
With application code, it is even better to use English notation :
"_previous"
On commandline, _p should also mean "previous" then ... this option in Spanish might be different from "_previous" = "_p"
Many greetings !0 -
Gracias por tu pronta respuesta, pero mi intencion es minimizar pulsaciones
usar _p o sp es muy similar (dos pulsaciones)me gustaria volver a poder usar solo "p" (soy un maniatico?!?!)Thank you for your prompt reply, but my intention is to minimize keystrokes
_p use or sp is very similar (two puffs)I would like to return it to use only "p" (I'm a maniac?!?!)0
