Sequence of attributes in attribute editor
Is there a way to change the sequence of defined attributes?
After definition they are stored in an unreproducible sequence. Only an afterwards manual change of tag and position per attribute change the sequence of content (not the attribute object itself). Depending on block definition the sequence is stable in principle but sometimes inverse in sequence.
  • The sequence is by order of selection when you create the block.
    If you create the block via window or crossing method you have no control over sequence.
  • I thought something like this. Unfortunately this cannot be changed afterwards in an easy way.
    Thanks.
    PS: In ACAD the sequence depends on the sequence of generating the attributes. This is more logic.
  •  I have seen add-on routines to edit block attribute order.  I think it was a LISP based one I saw, but I don't recall where to direct you to find it.
    -Joe
