Attach image by c# function
I tried to create function for attaching georefereced TIF files with TFW text file. I use part of code with some modifications from this web pages http://through-the-interface.typepad.com/through_the_interface/autocad_net/ Sources from that site are written for Acad, but it works also with BricsCAD in most of cases.
[code]
Transaction tr = doc.TransactionManager.StartTransaction();
using (tr) {
                            ObjectId dictId = RasterImageDef.GetImageDictionary(db);
                            ObjectId defId;
                            RasterImageDef rid;
                            if (dictId.IsNull)
                                // Image dictionary doesn't exist, create new
                                dictId = RasterImageDef.CreateImageDictionary(db);
                            // Open the image dictionary
                            DBDictionary dict = (DBDictionary)tr.GetObject(dictId,OpenMode.ForRead);
                            if (dict.Contains(sImgName))
                                defId = dict.GetAt(sImgName);
                                rid = tr.GetObject(defId, OpenMode.ForWrite) as RasterImageDef;
                            else
                                rid = new RasterImageDef();
                                // Set its source image
                                rid.SourceFileName = sFileName;
                                rid.ActiveFileName = ".\\"+System.IO.Path.GetFileName(sFileName);
                                // Load it
                                //rid.Load();  ...must be as comment BricsCAD create exception Error
                                dict.UpgradeOpen();
                                defId = dict.SetAt(sImgName, rid);
                                // Let the transaction know
                                tr.AddNewlyCreatedDBObject(rid, true);
                            // Create the raster image that references the
                            // definition
                            RasterImage ri = new RasterImage();
                            ri.ImageDefId = defId;
                            ri.ShowImage = false;
                            ri.Rotation = 0;
                            // Just place the image at the origin in a unit square
                            Vector3d imgScaleX = new Vector3d(dSx * ri.ImageWidth, 0, 0);
                            Vector3d imgScaleY = new Vector3d(0, dSy * ri.ImageHeight, 0);
                            System.Drawing.Bitmap img = new System.Drawing.Bitmap(sFileName);
                            Point3d imgTranslation = new Point3d(dTx, dTy - dSy * img.Height, 0);
                            ri.Orientation = new CoordinateSystem3d(imgTranslation, imgScaleX, imgScaleY);
                            BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId,OpenMode.ForRead);
                            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace],OpenMode.ForWrite);
                            btr.AppendEntity(ri);
                            tr.AddNewlyCreatedDBObject(ri, true);
                            // Create a reactor between the RasterImage and the
                            // RasterImageDef to avoid the "unreferenced"
                            // warning in the XRef palette
                            //RasterImage.EnableReactors(true); must be as comment BricsCAD create exception Error
                            ri.AssociateRasterDef(rid);
                        tr.Commit();
[/code]
This function add images, but it seems that DWG file is not correct. Everything is looks good till the moment when path to images or dwg is changed. Images appear only as rectangles without content.
  •  Do you resolve this?
    It is a little diferent attaching picture in Autocad and in Bricscad. I resolve this, if you need code I can post it later in the afternoon.
                       Try
                                Dim PIC_NAME As String = original_picture_name
                                Dim dictId As ObjectId = RasterImageDef.GetImageDictionary(Db)
                                If dictId = Nothing Then
                                    dictId = RasterImageDef.CreateImageDictionary(Db)
                                End If
                                Dim dict As DBDictionary = CType(acTrans.GetObject(dictId, OpenMode.ForRead), DBDictionary)
                                Dim recName As String = Picture_name_in_drawing
                                Dim rid As RasterImageDef = New RasterImageDef
                                rid.SourceFileName =  PIC_NAME
                                dict.UpgradeOpen()
                                Dim defId As ObjectId = dict.SetAt(recName, rid)
                                rid.Load()
                                acTrans.AddNewlyCreatedDBObject(rid, True)
                                Dim ri As RasterImage = New RasterImage
                                ri.ShowImage = True
                                ri.Orientation = New CoordinateSystem3d(New Point3d(x1, y1, 0), New Vector3d(1, 0, 0), New Vector3d(0, 1, 0))
                                Dim bt As BlockTable
                                Dim btr As BlockTableRecord
                                bt = acTrans.GetObject(Db.BlockTableId, OpenMode.ForRead, False)
                                btr = acTrans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite, False)
                                acTrans.AddNewlyCreatedDBObject(ri, True)
                                ri.TransformBy(Matrix3d.Scaling(picture_scale, New Point3d(x1, y1, 0)))
                         Catch
                                Exit Sub
                         End Try
