ddedit text highlight color
Hi
Does anyone know how or if I can change the highlighting color in the ddedit dialog box. The highlighting color is very close to our text color and so when it is highlighted the text is nearly invisible. I do not want to change the text color because we have been using this color for a very long time and is part of our standards.
Thanks
Doug
Thanks
Doug
            If I test this in V14.2.17 (and V15.1.11) I find that the highlight color automatically changes if the text color is the same as, or close to, the default highlight color. This even happens if only a portion of the mext has that color. Pretty sophisticated. What version are you using? The V14 Release Notes mentions that this behavior was introduced in V14.2.06.0
