Opening drawing file only one at a time problem - behaving like SDI
I was playing around with another program which has changed the behaviour of Bricscad.
Now when I click a drawing file it opens. Then I click another file it opens Bricscad again. resulting in 2 Bricscad windows.
It is behaving like SDI is on (like autocad) but I understand Bricscad does not have this feature.
Does anyone know how to fix?
I had that happen once, a long time ago. I believe it was a registry key, but I'm not sure which one.
HKEY_CLASSES_ROOT/Bricscad.load.dwg/shell/open/command sounds like it should control that.
Mine has the following value:
[code]"C:\Program Files (x86)\BricsCAD V13\bricscad.exe" "%1"[/code]
Is yours the same?0 -
Hi,Yeah mine is the same.I will keep looking.0
Have you tried turning on the SINGLETON variable? You can go it by typing Singleton Yes (Enter). That's supposed to prevent multiple instances.0
