ncopy
My engineers frequently use the function ncopy, in AutoCAD, to copy individual objects from a block.
In BricsCAD this function is not available.
The alternative I see is to make a copy of the block and explode it.
This results in extra work though.
Are there other / better options?
  • Already found an LSP that will do the job.
    [Attached file NCOPY.LSP removed because of Autodesk's copyright].
  • Sander, if you read the copyright notice in the file you have posted you will find that you are clearly violating Autodesk's copyright. This is unwise, especially on a forum run by Bricsys.
  • Sander,
    you can use the command REFEDIT and extract nested entities of a block...
    At the time the NCOPY program was written, neither existed a REFEDIT command nor the XREF techology.
  • Ncopy is available in Express Tools for BricsCAD.
  • Thanks for the warning Roy.
    I agree with you.
    Konstantin and Richard, thank you for your advice.
