How can I compile SDS
How can I make an application where users are not able to see the source code? The sollution was VBA, but now it is no longer supported by IntelliCAD...When loading LISP routines evrything (the source code) is visible to anyone, so anyone can copy this...Can I somehow create "a non copyable routine"?Will SDS compiled routine work?How to compile that?
