Gradient Background?
What does the "gradient background" control in settings? It does not seem to do anything in my build. I figured it would control the background of the modeling and mechanical workspaces, but it seems to do nothing. I find the backgrounds on those two workspaces too light. Is there any way to change it?
Thanks,
Nick
It seems to be used by _GRADIENTBKGON. Turn off using GRADIENTBKGOFF. These commands also change your viewpoint (Why??? Changes to plan in current UCS ?). You can also set backgrounds using _VIEW, which will override any existing gradient background. Then there is _PERSPECTIVE, which in turn has its own background settings!
Surely it could be made simpler..
Regards,Jason Bourhill
