positioning MTEXT
I am having trouble positioning MTEXT. When I try to Justify e.g. Middle Centre, the text does not budge and the 2 (or more) lines stay justified to the left and does not centre itself. I need all the text lines to be centred. I am stumped with this one. Help? I have (hopefully) attached an example (.png)
I think you forget to select the text in context of editing.Double click on the text and then select it before alignment by pressing Ctrl+A for example0
Hi Ilya,
Thanks for your response. I checked again, I did select all the text before I tried to justify it. I'm not sure if this is a glitch, I am on a trial version.
Ami,
If the MTEXT is Annotative, then this may be reason that you're having issues. I suggest you raise a support request and attach a copy of your drawing.
Regards,Jason Bourhill
Hi Jason, thanks.
Nope, text is not Annotative either, I can't seem to get the 'justify' to work at all. I'll do as you suggest and raise a support request.
Kind regards
Ami
